Vicky front seats I"am stll loooking for 1931 Vicky front seats??? 330-277-7939
Re: Vicky front seats If you are a member of the Victoria Association, you can place an ad in The Bustle. Contact Editor Dean Larson at [email protected].
Re: Vicky front seats There are 2 different front seats for a Victoria. From the beginning of production to mid June, the seats used a pivot rod to attach the seats to the floor. After mid June, the drivers seat would slide back and forth. The passenger seat had 2 fixed pivot. The seat back construction is also different between the two. The Victoria drivers seat is 1" wider than the passenger seat. They are different from a 2 door seat.
Re: Vicky front seats There was an article in The Restorer a few months back about a guy who was reproducing them.
Re: Vicky front seats I saw some on Snyder’s or Brattons.. they are pricey!
Re: Vicky front seats just curious, what is so diff about vicki vs tudor seats?
Ive owned both, but dont recall...... |
Re: Vicky front seats Ronn
Completely different shape and structure Vic has “hour glass” curved back with lower flap Tudor straight back… No where close Someone will likely post pics or easily seen in model a pics everywhere |
Re: Vicky front seats 3 Attachment(s)
These are the seats in my Steel-back Victoria. The middle picture is the driver's seat, and the right picture is the passenger's seat.
Re: Vicky front seats Bobs pics are early seats. Are you looking for early or late? The later has the wider drivers seat and the slide setup for the drivers side. The passenger side is same floor setup. And, they don’t have the loose flap but upholster down to the bottom cushion. Kinda hard to explain in words
Re: Vicky front seats Bert's Model A Parts sells front seat frames (left or right) made by Peter Gutierrez. Good place to start.
Re: Vicky front seats I have a very rough set. Cut new bases based upon the original.
