The Ford Barn
-   -   valve parts application (https://www.fordbarn.com/forum/showthread.php?t=338558)
Fordestes 05-13-2024 05:25 PM
I am trying to use sealed power v1558 valves in my A engine but I only have 5 on hand, I tried to use the sealed power number to buy some more but the warehouses and parts places want an engine vehicle application , they can't or won't cross the numbers over to their brand of parts, The guide application is for a 61-63 olds or pontiac 315 cu. in . engine . I cant find what engine manufacture /application the valves are supposed to fit, luckily I have plenty of valve guides on hand and 5 of the v-1558 valves already or I would just buy the kits available from the model A suppliers. appreciate you help . Fordestes .
jetmek 05-13-2024 08:58 PM
Re: valve parts application
I come up with gmc 305 v6 for that valve. Supersedes to s2326. Its not available thru SBI. Maybe try egge or ebay
Fordestes 05-13-2024 09:33 PM
Thanks a lot, I been researching and I was to the point of driving to a vendor and see if they could use the dimensions to identify a crossover application or number , now I can call the parts warehouse and order by application .
Thanks again. Fordestes
PC/SR 05-13-2024 10:18 PM
Not sure what you are looking for, but call Manley with the dimensions you want, size, length, diameter, etc and they will build it for you and the price is not bad. Google their catalogue and you may find a stock valve that is just right for your application.
motordr 05-14-2024 07:03 AM
I was in the same situation earlier this year, it seems that SP V1558 is no longer made. I found some on eBay under the GM part number.
johnneilson 05-14-2024 07:18 AM
Try SI valves in So Cal
They make customs or obsolete
John
Fordestes 05-14-2024 12:52 PM
can you give me the G.M. Part number, mabe I will get lucky, I have 5 on hand and the guides on hand, I am 3 valves short, I I didn't already have the guides ,retainers and keepers I would opt for one of the retro modern valve kits offered, the G.M Valves have an abundance of material on the face and should last for another century.
Dan McEachern 05-14-2024 03:26 PM
painfull, but.........
https://www.ebay.com/itm/29620413105...Bk9SR7iCvIzvYw
motordr 05-14-2024 08:36 PM
The GM part number:2368099.
I was using NOS Model B lifters with my Burtz cam in my Burtz block. The new valves from major model A suppliers were way too short, the V1558 valves where long enough to be shortened to the correct gap.
motordr 05-14-2024 09:31 PM
Oldsmobile obsolete has one listed.
BRENT in 10-uh-C 05-15-2024 06:44 AM
Originally Posted by Dan McEachern (Post 2311379)
Dan, look at the hole in the end. That kinda looks like a Model-T valve.
Dan McEachern 05-15-2024 11:02 AM
Eh- hopefully just a really out of focus picture!!! kinda looks like there might be a keeper groove at the end.
Fordestes 05-15-2024 04:22 PM
I tried their web site but couldn't find anything , I'll try again ,Thanks.
Fordestes 05-15-2024 04:25 PM
I think this one may be for sale for a long time at that price.thanks.
Fordestes 05-15-2024 04:29 PM
that is what I am finding out, I found enough to finish this engine from one of my old sources in Louisiana at $10.00 each , now to find the rest for another engine I have underway , I will need 4 more valves to complete it, thanks for all your help .
Dan McEachern 05-16-2024 01:09 AM
Just be aware those were never inexpensive valves. I have some and they were about $15.00 each at least 10 years ago.
Fordestes 05-18-2024 04:39 PM
I want to thank Mr. Bruce for helping me out on my search for the valve train parts, and also I learned a lot of useful information about these cars from him, is .002 interference fit right for the guides press fit in the block, I don't want to trash a good block by forcing the guides into the bores and causing a crack. Thanks Fordbarn !
