The Ford Barn
-   -   Lake Pipe insalation (https://www.fordbarn.com/forum/showthread.php?t=337493)
Robs 04-06-2024 10:13 PM
I bought a set of 70 inch Speedway lake pipes didn't come with instructions where do you mount them to? are they mounted to the frame or rocker panels? Any help appreciated newbie here learning as i go Thanks
Lanny 04-06-2024 11:56 PM
Re: Lake Pipe insalation
Are there any brackets that came with the pipes ?
If so, can you describe the brackets to us ?
pistonbroke 04-07-2024 07:57 AM
What are you hanging them on? Different cars and trucks use different methods. Tim
Lanny 04-07-2024 10:12 AM
I know he has a '49 Ford car he wants to put them on.
I would call Speedway and perhaps they could see if
another box of pipes has the instructions and make a copy.
Also, ask to talk to one of their workers that could give
you some pointers, as to the best way to mount them. :)
Juergen 04-07-2024 12:54 PM
What are you using the for? Some custom jobs used them for looks only so mounted them directly to the body/running boards/frame and hid the input under the frame. I attached them to the exhaust pipe and T-d off the input to go through the mufflers when the lakes pipe was closed. In this case treat it like an exhaust pipe and use appropriate exhaust hangers. Some states consider this a cutout and can write a citation for this. The worst part is when your buddies want to hear the open pipes after you have done a pub crawl. Not good practice.
TJ 04-08-2024 11:13 AM
When I bought mine from Speedway some time back you could also buy the stainless brackets to hang them on the car. On my '54 Merc I drilled some extra holes in the body brackets to mount them with the Speedway brackets. You could also use the rocker panels for mounting.
Robs 04-10-2024 10:48 AM
yes got some brackets but not sure where to attach them dont want to be poking holes in a solid unless only can be mounted to rockers and i have to thanks
Robs 04-10-2024 10:49 AM
thanks
