modern paint code/mix for 1965 thunderbird interior color? NOT LOOKING FOR DYE
I am looking to match light aqua interior paint from a 1965 Thunderbird in a modern ppg formula. I had them try the spectrum analyzer and it could not get a good match due to the texture. |
Re: modern paint code/mix for 1965 thunderbird interior color? Can you post the INT TRIM CODE off the PATENT PLATE?
Re: modern paint code/mix for 1965 thunderbird interior color? Call Pat Wilson's Thunderbird Parts in NJ - he may have some information. he specializes in later Tbirds
Re: modern paint code/mix for 1965 thunderbird interior color? I do not have the data plate, it is an interior that was put into my 51 Mercury from 65 t-bird.
Re: modern paint code/mix for 1965 thunderbird interior color? |
Re: modern paint code/mix for 1965 thunderbird interior color? The formulas and composition of paints have changed so much that the early codes aren't much help.
Re: modern paint code/mix for 1965 thunderbird interior color? PPG was able to provide a perfect match for my 58 Edsel Pacer for my paint supplier. Spend a little time with one.
Re: modern paint code/mix for 1965 thunderbird interior color? Quote:
Example: code "T" Skyhaze Green in '54 is the same paint color as Thunderbird Blue in '55. And the same 'name' might be used for slightly different paint colors. Ford paint color names and code letters could change from year-to-year, or not. As the Marketing Dept. could chose to keep things 'new & improved'. The various paint manufacturers have their own letter/number color formula designations not directly related to the in-house FoMoCo numbers. As mentioned, the older ingredients may no longer be available, some discontinued by govt regulations. . |
Re: modern paint code/mix for 1965 thunderbird interior color? ... whew ... OP asks a simple question and the GREAT DEBATE starts ... If I guessed right on the INT TRIM CODE from his color description, the INT TRIM CODE is 27 - LIGHT AQUA CRINKLE ALL VINYL. Where as a regular auto paint store may not have the info or interest to find the paint code, there are suppliers that specialize in older cars - READ HERE - https://forums.fordthunderbirdforum....or-code.14913/ FORD bought it's paints and supplies from outside vendors such as PPG - DITZLER. These companies were suppliers to the assembly plants and made the colors to FORD specs. There is no big mystery. |
Re: modern paint code/mix for 1965 thunderbird interior color? Try www.paintscratch.com if you have the codes and the name of the color. They may be able to help you. They helped me for a Subaru color that I have on my 54 Ford.
Re: modern paint code/mix for 1965 thunderbird interior color? 2 Attachment(s)
Here is the Dupont chip book from back in the day
