The Ford Barn
-   -   Cluster Gear ID (https://www.fordbarn.com/forum/showthread.php?t=336841)
Seth Swoboda 03-19-2024 08:10 AM
Cluster Gear ID
3 Attachment(s)
Can anyone idendify this cluster gear for me? The hole in the center is 3/4 in. It is very similar to a V8 60 cluster gear. The burs on the end gear are throwing me off. Thanks.
Terry,OH 03-19-2024 09:15 AM
Re: Cluster Gear ID
The teeth at the end of the gear hold a thrush washer in place. Gear appears early like 35-36
petehoovie 03-19-2024 11:22 AM
Re: Cluster Gear ID
https://www.fordbarn.com/forum/attac...3&d=1710853766
https://www.fordbarn.com/forum/attac...4&d=1710853766
https://www.fordbarn.com/forum/attac...5&d=1710853766
Mac VP 03-20-2024 04:47 AM
Re: Cluster Gear ID
Post the tooth count. We should be able to figure out exactly which gear it is.
Seth Swoboda 03-20-2024 08:56 AM
Re: Cluster Gear ID
Looks like the big gear is 29 tooth. If you need the other tooth counts I'll get them at lunch today.
rotorwrench 03-20-2024 10:40 AM
Re: Cluster Gear ID
Part straight cut spur gears puts it in the pre-1936 area for passenger cars. Pickups may have had spur gears for a bit longer but most went to helical after the start of the 1936 model year.
Seth Swoboda 03-20-2024 07:40 PM
Re: Cluster Gear ID
29-19-17-13 are the tooth counts. This is V8 60 I believe???
