Holley 94 4 bolt base? I have a couple Holley 94 carbs with a 4 bolt base instead of the 3 bolt base.
Do you know where the 4 bolt bases were used? I would like to obtain a couple more 4 bolt bases. Thank you! |
Re: Holley 94 4 bolt base? The last years of the Lincoln V12 used a 4 bolt base 94 type carb. Would probably be pretty rare.
I think there were some non Ford applictations that used the 4 bolt too, like maybe IHC trucks. There was also one produced for Volkswagon Beetles in the late 60's and in the 70's called the Bug Spray. Sal |
