The Ford Barn
-   -   BB stamped on my 36 ford (https://www.fordbarn.com/forum/showthread.php?t=335915)
hombres ruin 02-19-2024 04:38 PM
Hi guys I have a 36 roadster and my 21 stud has BB stamped on the block on the passenger side. Does this indicate a truck engine?
Model51 02-19-2024 05:36 PM
Re: BB stamped on my 36 ford
It's likely a re-builder or inspectors mark - at least that's what I think.
Production engine blocks for 1935 and 1936 truck, car and commercial engines are the essentially the same except there are different heads, intakes, etc., but the engines were basically the same.
hombres ruin 02-20-2024 07:47 AM
Thanks for the info. Mine has cast iron heads .
flathead34 02-20-2024 08:40 AM
The BB means that the body was built by Briggs. Our 35 has it also on the fire 3wall in big letters.
Model51 02-20-2024 03:45 PM
Ford used cast iron heads for service replacements sometimes when the aluminum heads failed for various reasons so it's not unusual to have a car engine with cast iron heads instead of aluminum. The originals would have been aluminum.
Production truck engines almost always have cast iron heads and intake manifolds as standard equipment but these parts are interchangeable with aluminum versions and vice versa.
Charlie Stephens 02-20-2024 04:50 PM
Engines were not serial numbered except for those going to a few locations that required it. Are there any numbers after the BB?
Charlie Stephens
deuce lover 02-21-2024 01:20 AM
BB, insert mains- Big Bearing?
