The Ford Barn
-   -   Flywheel 1934 1936 , (https://www.fordbarn.com/forum/showthread.php?t=335537)
john greco 02-06-2024 10:57 PM
Can someone spread some light please , when did the flat head v8 go from the dished , (recess )flywheel to the flat one ? Will the interchange ? Thanks again
cas3 02-07-2024 03:59 PM
Re: Flywheel 1934 1936 ,
I believe the flat 10" flywheel came in about 41. The dished are all 9" I think. The crank flange is the same model T thru 53, but the 8ba's use a different flywheel due to starter location. 8ba flywheels have thru holes for the pressure plate, where as earlier v8's have blind holes there.
Kurt in NJ 02-07-2024 04:05 PM
Up to 34 it was same as model A
