Help with E-Z Steer Kit Hi I don’t want my last thought to be, STUPID,
Not including the pitman arm, would this be the sequence for assembling the parts of the Kit. Spring, plastic cap, ball ( I found it was not difficult to c- clamp it in place) Plastic cap, and then the large threaded cap. Thanks for the help. |
Re: Help with E-Z Steer Kit Hello, that’s what I did also.
Re: Help with E-Z Steer Kit Here's the instructions.
https://www.snydersantiqueauto.com/c...0New%20Von.pdf |
Re: Help with E-Z Steer Kit Yahoo!! Thanks very much, I was not wanting to redo.
God bless. |
Re: Help with E-Z Steer Kit Does the E-Z Steer kit make a marked improvement?
Re: Help with E-Z Steer Kit Hello, it’s hard for me to answer that as I also rebuild the steering column, replaced all the steering balls at the same time, rather wear out the plastic inserts than replace the steering balls again, the car does steer nice and quickly, almost like my MG .
