The Ford Barn
-   -   Shoebox door removal help (https://www.fordbarn.com/forum/showthread.php?t=335245)
Babyboomerboy 01-29-2024 10:28 AM
Heading out to a field that has a 50 ford sitting there with a door I need. What tools should I take to remove the door? I'm sure the hinge screws are rusted. No electrical outlets for any power tools, all I have is some hand tools. Any suggestions would be appreciated as I have never done this before. Thanks
Kube 01-29-2024 12:22 PM
Re: Shoebox door removal help
Take six-point sockets and if the bolts don't want to seem as they want to come out, then twist them in and hopefully, break them off.
If possible, bring an oxy/acetylene torch with you and cut the heads of the bolts off.
deuce5wndw 01-29-2024 12:53 PM
Those hinges are held on by Phillips screws so a hand impact or cordless drill to drill them out. As a last resort a sawzall to cut the hinges.
Don T 01-29-2024 01:00 PM
I believe the bolts you intend to remove on the chassis are have a phillips head. With a sturdy screwdriver give them a wack on the screwdriver with a big hammer. If you can get penetrating oil in behind on the threads and let it soak for DAYS. Heat is your friend, as I recall I got the heads red hot with oxy/acetylene and then let them cool. The big issue is to NOT strip the phillips head. Buy, rent or borrow a battery operated impact hammer if they cannot be removed by hand. If the chassis is toast blow the heads off with the oxy/acetylene. Good luck!
Kube 01-29-2024 01:05 PM
Thanks guys... thought they were bolts.
tubman 01-29-2024 01:32 PM
This is a very difficult task; even more so if the car has been sitting in the field for any length of time. Unless you have an Oxy/Acetylene unit or a portable air compressor, be prepared to spend hours with a good rechargeable drill (and spare batteries).
About the only thing that even makes this even a remotely reasonable task is shown in this thread on the H.A.M.B. : https://www.jalopyjournal.com/forum/...ade-easy.6015/.
Perhaps you could get really lucky and the door you want had been replaced recently.
1956 ford 01-29-2024 02:47 PM
take battery Sawzall and cut the hinge and be going
Joe B. 01-29-2024 07:22 PM
Drill the countersunk heads off of the machine screws?
tubman 01-29-2024 08:10 PM
Probably the best suggestion yet. But again, bring spare batteries.
Don T 01-30-2024 04:17 PM
You might be able to drill the heads of the bolts off after you have turned the phillips head shape into a round shape with punches. Bring lots of bits.
