rochester 37001 2g carb stage 1 would this be the proper carb to use on my flatty , with manifold to go with it?
thanks kurt |
Re: rochester 37001 2g carb stage 1 Quote:
https://content.speedwaymotors.com/P...ef824f3e74.jpg |
Re: rochester 37001 2g carb stage 1 I looked this up on the web, and Jeg's says it is a large base Rochester 2G. The large base carburetors will not fit the Mercury 4-bolt manifolds we all like so well. A small base 2G will bolt right on. The bores of the small base are 1 7/16" which is quite a bit larger than the merc manifold. I bore the manifolds to match the carburetor and have never had a problem breaking through. I don't know if that would be the case with the large base series.
You really want a small base 2G for this. To be specific, you need one from a Chevrolet because of the side placement of the fuel inlet that is just about where the stock inlet is located and allows the use of the stock fuel line. The other carbs (like the one in the picture "petehoovie" posted), have the fuel inlet pointing forward, which requires a much more complicated fuel line. FYI : The small base bolt pattern is: c-c 3 1/4 x 1 7/8 inches, while the large base is: c-c 3 11/16 x 2 1/16 inches). There are adapters available, but they are expensive because the sizes are so close. https://www.dashman.net/category.php?id=32 |
Re: rochester 37001 2g carb stage 1 |
Re: rochester 37001 2g carb stage 1 That ad clearly shows the difference between the fuel inlet locations. Too bad it's over 2 years old. Sadly, I have found that inflation has hit the small base 2G market harder than most other things.:(
I had watched the LITTLE 2Gs getting more and more expensive going back for quite a while, and I surely haven't been to a swap meet in quite some time. Of course, like everything else we folks piddle with, this junk has gotten old. Some of these damned 2Gs are approaching 70 years old and just hidden away. I guess that makes 97s and 48s downright ancient. Coop . |
Re: rochester 37001 2g carb stage 1 I have neighbor friend who has a 50 year collection of stovebolt chev trucks. Some 216, mostly 235, and 261. His early collecting was ;47--54, but lately has a lot of '55-'57 trucks and parts. Could his stash contain the one we are discussing here?
Re: rochester 37001 2g carb stage 1 From the way you describe it, probably several. From my experience, the truck carbs are usually manual chokes, which can be good or bad. Since the Merc's of that era were automatic chokes, matching them up with the proper type of automatic choke carb greatly simplifies installation. However if you like manual chokes, it's a good thing.
Coop . |
Now that you have a lathe, what's keeping you from converting a Chev distributor? :D:D |
