The Ford Barn
-   -   Leaf spring pin removal (https://www.fordbarn.com/forum/showthread.php?t=334886)
Southtowns27 01-17-2024 07:17 PM
1 Attachment(s)
'46 1/2 ton pickup. How does the forward leaf spring pin remove from the rear springs? Is that a wedge pin that I've circled? Remove the wedge pin then the main pin should pull out? Waiting for my service manual to arrive...
Thanks in advance!
alanwoodieman 01-17-2024 08:49 PM
Re: Leaf spring pin removal
yes, should be a nut to remove then knock lock pin out
petehoovie 01-17-2024 08:55 PM
Thanks in advance!
https://www.fordbarn.com/forum/attac...1&d=1705537045
