The Ford Barn
-   -   Sportlite Cable (https://www.fordbarn.com/forum/showthread.php?t=334576)
Brokenvette 01-08-2024 01:24 PM
Sportlite Cable
Where can you buy the shielded cable for these lights ?
nkaminar 01-08-2024 01:35 PM
Re: Sportlite Cable
I am not sure what you want. Restoration Supply, https://restorationstuff.com/catalog...atalog2020.pdf has a lot of stuff including the spiral wound stainless conduit, like the one used for the headlights and horn but smaller in diameter. The conduit is on page 11 of their catalog.
Y-Blockhead 01-08-2024 03:06 PM
Re: Sportlite Cable
Restoration Supplies has armored wire available in different gauges on page 4. https://restorationstuff.com/shop/#fb0=4
This is the same as the wire used for the '30/31 dash light. They sell it by the foot.
Brad in Germany 01-08-2024 04:33 PM
Re: Sportlite Cable
Bratton's sells the correct gauge armored cable by the foot ($2.25 per foot):
https://www.brattons.com/Images/19680.jpg
Brad in Maryland
Brokenvette 01-08-2024 04:56 PM
Re: Sportlite Cable
Thanks to all for the replies.
Y-Blockhead 01-08-2024 05:11 PM
Re: Sportlite Cable
Brad in Maryland
I thought Bratton's was where I bought it but could not find it, I was searching for armored wire, not cable. Thanks. Part #19680
rotorwrench 01-08-2024 07:23 PM
Re: Sportlite Cable
That armor surrounds an insulated conductor wire. It's not uncommon to refer to it as armored cable. It's just smaller gauge than the larger multi wire armored cables that are used in place of hard conduit wiring used in home & shop electrical construction.
Planojc 01-09-2024 09:45 AM
Re: Sportlite Cable
Got mine from Brattons.
