8ba into 35 coupe ? What changes to the 8ba to fit into 35 ford coupe ?
Re: 8ba into 35 coupe ? Here's some good info. to get you started. Also do a search on Fordbarn on how to install an 8BA in a 36 coupe. Lots has been written on this swap. Be sure to consider radiator top hose clearance and fan blade clearance.
https://www.bing.com/search?q=how+to...ANAB01&PC=HCTS plus this: https://www.fordbarn.com/forum/showt...+36+ford+coupe Also, read this: https://www.fordbarn.com/forum/showt...=8ba+1936+ford And this antichatter (steadyrod) adaptation modifications. https://www.fordbarn.com/forum/showthread.php?t=313652 and https://www.fordbarn.com/forum/showt...tichatter+rods |
Re: 8ba into 35 coupe ? thank you ! I did do a search but didnt come up with much. Wrong combo of words I guess.
Re: 8ba into 35 coupe ? ABONES: Sometimes it's better to "Google" the question you have rather than do a Fordbarn search. Then, that will provide additional leads on other sites.
Re: 8ba into 35 coupe ? Quote:
As Jim ("19Fordy") mentions, a mechanical FAN can be quite difficult to shoehorn into a '35 or '36 with an 8BA because the radiators lean back toward the rear leaving little precious room for a fan. And since we have heard that electric fans are about as un-cool as taking your own sister to the prom, we decided to come up with a better way to employ a mechanical fan. Click the link BELOW for a thread describing the fan assembly that we designed and built for his 8BA. Works great and cools his engine in the Florida summertime heat. Coop https://www.fordbarn.com/forum/showthread.php?t=278828 https://www.fordbarn.com/forum/attac...2&d=1476383810 |
Re: 8ba into 35 coupe ? There are two areas you have to look at therear is the easiest . Have the flywheek re drilled for the 9" pressure plate and this will bolt to the 35 trans. So Will the stock 10: but the 1 3/5 input shaft will requie a different disk.
The front is easiest with 8Rt eater pumps, I'd also considering the use of eletric fam, a two stage fan is best and the junk yards are full of them. Now everybody has their own idea whats best, I'm lazy and cheap The load a matic dist /carb work very good . Have Charly check it out> Gramps/ PS |
