BRAKE THEORY 001 - H.A.M.Bone They are still at it over there -
https://www.jalopyjournal.com/forum/...stion.1307162/ Quote:
Re: BRAKE THEORY 001 - H.A.M.Bone Kultulz, I am not a member over there. However, I can see his photos. My streetrod has underfloor brakes. I found out with residule valves you can not effectively bleed brakes with a vac gun. And the first step should NOT be to have the assistant start off by pumping the brakes up before cracking the bleeder valves. All that does is broadcast air bubble throughout the system. My Dad is the worst, so I bleed brakes with my wife. LOL
Re: BRAKE THEORY 001 - H.A.M.Bone The brake problems and information on all the auto sites is all over the place. Good, bad, dangerous, you name it. I just went thru that on a friends car. The right front caliper partially locked up and being pissed off, he drove it home. That was problem 1. Right front bearing disintegrated from heat. Rotor blue. All the high temp wheel bearing grease in a puddle in the hub cover. I call that pilot error.
But with everything replaced, the front wouldn’t bleed. That “combination” valve had failed in the closed position (which some say they do and some say they don’t) but all it would do is dribble fluid. The supplier still had his 10+ year old order and sold him a replacement. Different unit (we don’t use that one anymore) and we finally got it on the road. After finding an odd ball adapter to hook the rear lines up due to a fitting mis match. My cars have residual valves as required and adjustable pressure valves to the rear. Linings that match. Pressure checks at the wheel. They work well but it’s complicated, fairly expensive, and requires someone who really knows what they’re doing. No “combination” valves from some other system because it’s available cheap. What amazes me is we don’t see more braking related accidents on hot rods. Must be because we’re all older and driving careful. |
Re: BRAKE THEORY 001 - H.A.M.Bone Here It Is In A Nutshell -
Re: BRAKE THEORY 001 - H.A.M.Bone 2 Attachment(s)
See if this ill shows large enough to cipher -
https://www.fordbarn.com/forum/attac...7&d=1703766292 https://www.fordbarn.com/forum/attac...1&d=1704161766 Unbelievably sloppy install. |
Re: BRAKE THEORY 001 - H.A.M.Bone Brake line mounted under the frame?
Re: BRAKE THEORY 001 - H.A.M.Bone Question. With 4 wheel disc brakes do you have this problem?
Re: BRAKE THEORY 001 - H.A.M.Bone Quote:
The main thing is that the early cars had the MC mounted on the frame rail under the driver's floorboard (before swing pedals). That would put the MC reservoir below the wheel cylinder/caliper and gravity would cause the brake fluid to drain back (gravity) to the MC, resulting in a soft pedal on first application.. A 2# RESIDUAL VALVE needs to be plumbed in to hopefully prevent that on DISC APPL. The 10# RESIDUAL VALVES needed with drum brakes (at that period) would cover DRUM but DISC would always have a slight drag on the rotors with the 2# RV. If you mounted four wheel disc, the problem would be worse. |
Re: BRAKE THEORY 001 - H.A.M.Bone photo look clear to me
Re: BRAKE THEORY 001 - H.A.M.Bone A Good friend whom I was assisting with his build mounted the master on the frame rail. Disc/disc setup. His reservoirs were on the fire wall. Convincing him that residuals were not required because the reservoirs were above the wheel cylinders ended up with "pull the brake lines off the master and watch the fluid run all over the place". After the mess was cleaned up he conceded. Mean ol Mr. Gravity keeps thing tight when the reservoir is above the wheels!
Re: BRAKE THEORY 001 - H.A.M.Bone 1 Attachment(s)
I have no experience with this type of braking, so bare with me please. So the theory is to use a frame rail mounted MC without reservoir(s) and the weight of the fluid in the remote reservoir(s) and lines will prevent the brake fluid from draining back (gravity) from the caliper (without a RV) as the MC itself will be/remain full? Eliminating the RV would rid the problem of a slight drag on the rotor. |
Just like the ENERGIZER BUNNY, it keeps going and going ...
To Wit - https://www.jalopyjournal.com/forum/...rakes.1307775/ Quote:
I think he is making a tanker and runnin' shine with those copper worms ... :D |
Re: BRAKE THEORY 001 - H.A.M.Bone ... :eek: ... - I'LL BE DAMNED ... IT'S TRUE! - CPP Master Cylinder, MCPV-1, Polished Aluminum, 1" Bore - Quote:
Re: BRAKE THEORY 001 - H.A.M.Bone I was describing a MC without the reservoir integral or the reservoir atop the MC (closed except for fill and outlet fittings).
If remote as you describe (firewall mounted), the weight of the fluid (in the reservoir(s) and lines) would preclude the front caliper line draining back after pressure release to the MC due to gravity? He had no soft pedal/slow take-up after that (removal of the external #2 RPV)? Does he have the GM METRIC CALIPERS? Like I said, I never fooled with anything this early so I am on a learning curve. |
Re: BRAKE THEORY 001 - H.A.M.Bone Yes, that is correct. He used a "regular" Corvette master with a modified top, aluminum with fittings for the lines to the remotes. Look inside a regular master and watch the cylinder when pushing the pedal. Again a 4 disc setup.
He had perfect pedal feel and response. Firebird rear disc, after market kit for the front, 11" rotors. I drove the car for a young lady's wedding and put about 150 miles on it. Never felt funny or out of sorts. He has unfortunately passed and I sold the car for the widow to a fellow in WA. The pictures I had are unfortunately on the failed hard drive from my now dead old machine.... |
EDIT - 17FEB2024 [Let me qualify the above statement. There are DISC/DISC PPV's. Usually, when OEM designs a four wheel disc car, the front and rear systems are balanced by design (same as a four wheel drum car) or operated with ABS. If the builder uses differing rated vehicle braking ends, there may/will be a need for a PPV. Same situation on a rear disc swap. The vehicle ends will not be matched (same as a DISC/DRUM swap).] If one retrofits a car with front and rear disc that the wheel ends are from differing vehicle(s), chances are yes. Even some OEM installs will use a DISC/DISC COMBINATION VALVE (PDV and PPV - NO METERING and/or RESIDUAL PRESSURE VALVE) to allow for any inherent imbalance. Say you have a car and use GRANADA DISC front and later style CROWN VIC disc on the rear. There is no way that they can work together correctly. One will overpower the other at some point, especially on a panic brake application. Then you go to PPV(s). And we haven't gotten to the correct style MC for DISC/DISC and the amount of fluid volume needed to move the chosen caliper pistons correctly. A lot to cipher on and most of these so-called kit makers haven't the faintest clue or concern. WILWOOD offers correct balanced DISC/DISC (as I am sure of others) kits but I have never checked the offered kits and what they fit. |
Re: BRAKE THEORY 001 - H.A.M.Bone - ANOTHER CONTINUING SAGA ENTRY IN THE USUAL FASHION - TO WIT - https://www.jalopyjournal.com/forum/...ravel.1309066/ |
Re: BRAKE THEORY 001 - H.A.M.Bone 3 Attachment(s)
When bleeding a DUAL RESERVOIR MC SYSTEM (w/ PDV included), you always use a shutter valve centering tool in the PDV (replaces switch) for the bleeding process. If that shuttle pins moves to one side or another during bleeding, it is going to interfere with fluid pressure/volume in either of the circuits - |
