Need help ftting rear glass? 39 truck I cant find any instructions or do’s and dont’s or anything. No information at all on the method of fitting the rear window in the cab of mg 1939 truck. I searched youtube and google but found nothing. Do I or should I use some type of liquid sealer to set the glass in so it wont leak?
Re: Need help ftting rear glass? 39 truck Hello, Im by far no expert. I took my rear glass out to replace the gasket a couple years ago I installed the new gasket on the window and wrapped a 3/16 nylon cord in the body groove lubed it up with soap and water then pushed the window and gasket into the opening wiggling some of it in place then pulled the cord making the gasket make contact worked for me good luck
Re: Need help ftting rear glass? 39 truck Seen one glass guy use Go Joe hand cleaner to lube the rubber going. Lube the rubber after the glass is in the rubber. Rope cord and are a hose removing hook.
Re: Need help ftting rear glass? 39 truck 2 Attachment(s)
Re: Need help ftting rear glass? 39 truck I believe the original method of installation relied on the window channel material to seal the back window opening. I don't have a good enough original to determine if there was rubber material attached to the window channel or if they just relied on the fabric of the window channel material.
To be safe I'd run a small bead of black RTV on the inside lip of the back of the window opening, then press in the window glass with the window channel and then lock it down with the garnish molding strip and screws. You can wipe off any extra RTV from the outside of the glass. It's mostly up to what you think is best and there's really no wrong way to go, but a small bead of RTV might be best. |
Re: Need help ftting rear glass? 39 truck Be careful with silicone sealers as many will attack the glass. Glass shops use special, IE dedicated to glass contact sealers.
There was no sealer from the factory, and I don't see any reason you'd need it now. I use glass cleaner sprayed on liberally vs. soap. Soap will often bubble long after the installation has been completed. Glass cleaner will not... |
Re: Need help ftting rear glass? 39 truck The glass is set into a rubber gasket and then the interior trim holds it all in place.
https://bobdrake.com/search?type=pro...up+rear+window |
Re: Need help ftting rear glass? 39 truck 1 Attachment(s)
Re: Need help ftting rear glass? 39 truck Quote:
Re: Need help ftting rear glass? 39 truck The interior trim piece is the same '35-'39. Drake and other suppliers sell the rubber channel by the foot. Cut it to fit, rubber cement on the ends with the seam at the top. Tightening the screws on the interior trim compresses the rubber channel to make a water-tight seal.
Re: Need help ftting rear glass? 39 truck Edit: I replied below before seeing that the 39 is different to the 41.
I can offer some advice. I did this on my 41. Don't use too much soapy stuff. My hands slipped and I dropped the glass and broke it. Make sure there is something soft for the glass to land on if you do drop it. A second pair of hands is very helpful. I have a video that shows my misadventure. Do not watch if you are not prepared for strong language. That said, some have said this is the funniest video they have ever watched. Mart. It going ok: https://youtu.be/_T4dXtPVg4Y It going wrong: https://youtu.be/boCoiHmcbOg |
And never use WD40 to lubricate the rubber. Use only window cleaner. That's what the guy who sold me the windshield and door glass for my '39 p/u. All his advise regarding the install was spot on so I have no reason to doubt the WD40 warning. |
Re: Need help ftting rear glass? 39 truck For anyone who needs to know the rear window seal is ford part number B-704220
So now I know what rubber seal to use do I need to use some sealer like rtv between the metal and the rubber? |
Re: Need help ftting rear glass? 39 truck I heard not to use generic rtv, but a specific sealant for windows. Not sure where I read it, but it is available, not necessarily for automotive use.
Re: Need help ftting rear glass? 39 truck I would think urethane would be better, black like they now use to set windshields
Glass shops use a sealer made specifically for glass. You should not need a sealer; Ford didn't. |
