Remove rear fender on Model A pickup What is the process for removing one rear fender on a Model A pickup ?
Re: Remove rear fender on Model A pickup Quote:
Re: Remove rear fender on Model A pickup Remove the bolts that are at the running board/fender connection, a couple of bolts splash apron/fender and then the bolts that hold the fender to the bed. Undo the wiring if there is a light on the fender. :)
Re: Remove rear fender on Model A pickup Thank you, I appreciate the quick replies.
