Electronic distributor 2 Attachment(s)
Hello all!
Please share pictures or videos of the installation of electronic distributors (1939 Ford pickup, but any info for flatheads around that year will help). I want to change the original distribution to a new one due to issues for which I can't find a solution. I have basic knowledge of automotive repair. |
Re: Electronic distributor If you put that distributor on there you won’t be pleased. Stick with points or get a stromberg e-fire. I won’t go away from points but if I had to the efire is the only one with a proper advance curve and module that will hold up
Re: Electronic distributor Hi. Got a 1933 stock engine with stock points distributor (rebuilt by Michael @thirdgenauto). Engine runs like a charm, purrs like a kitten. I would not go electronic for a million...
Re: Electronic distributor Please explain in detail what the problem is with what you have. I know of no problem with a stock distributor that cannot easily be solved. Whatever your problem is, there absolutely IS a solution. Like Michael said, don't waste your money on the pictured distributor.
Re: Electronic distributor Quote:
Re: Electronic distributor 1 Attachment(s)
Hmm? For a $100, might be worth a try. https://www.speedmaster79.com/Ford-F...istributor-Red
https://www.fordbarn.com/forum/attac...1&d=1699279854 |
Re: Electronic distributor Please elaborate on your problem. There are several on this board that can help you.
At the least, so that if you do install the pointless distributor, you will not have the same problems. Ford's dual point distributor should be fine, could you an overhaul, 3rd Gen can help with that. If you decide to go with the electronic distributor, choose one that is not made in china, it will be el crapola. Was at SEMA this week and there are a ton of china and india vendors selling their crap. |
Re: Electronic distributor > it will be el crapola.>
Maybe. Maybe not. I've been running an R2R on an OT car for 8 yrs now. |
Re: Electronic distributor My guess is what was made in China 8 years ago is vastly superior to what is being made there now.
Re: Electronic distributor Thank you all for the replies!
The pickup is located abroad, where I can't find parts, or experts that calibrate the distributors, so I would prefer using the ready-to-go dizzy. My engine was working well, but when I installed new caps, rotor, points, sparkplugs, and condenser, the engine started to backfire. |
Re: Electronic distributor From the information it says if you live in California it may cause Cancer
