Model A Delco Accessory 6 Attachment(s)
Just bought a spare engine and it has an additional item on the passenger side. It looks like a second generator or maybe a clutch. Not sure what it is. It has a DELCO name plate on it which I thought is usually GM
Anyone know what this is used for? |
Re: Model A Delco Accessory Kind of looks like a generator. Does it have brushes or a commutator where those slots in the body are at the drive end?
Re: Model A Delco Accessory Could be a home made governor. I seem to remember an article about how to modify an old generator to turn it into a governor. From the photos it looks like the lever moves back and forth. Can you see something inside that looks like flyball weights?
Re: Model A Delco Accessory Seconded on a governor. I had a T engine that had the same looking thing installed, and it was used as a log splitter.
Re: Model A Delco Accessory Could be a welder generator. When I was a kid my dad had a similar looking generator on an old engine that he used to electric weld with. I always thought it was an airplane generator. It wasn't a very good set up.
Re: Model A Delco Accessory With the lever it makes me think an in/out clutch of some type that activated whatever was bolted to the back of it. Welding generator, hydraulic pump, etc.
Re: Model A Delco Accessory I don't remember ever seeing one, but as a kid in the 50's I remember hearing of Delco generator sets that people used for indoor lighting before public power systems began. I think they may have used the old hit/miss well pump type motors. The lever could be a disengage to reduce the load on the engine for starting.
(Just thinking out loud, Ha ha) Al Hook |
Re: Model A Delco Accessory Quote:
That lever....hmmm. |
