The Ford Barn
-   -   Battery Cable Routing for 34 (https://www.fordbarn.com/forum/showthread.php?t=331746)
Abcarswell 10-06-2023 11:26 AM
2 Attachment(s)
My brake job has expanded into a replacement of the rotted out battery tray and cables on my Fordor. The ground strap was shot and also attached to one of the battery tray bolts which from what I read is not correct. The cable to the starter switch had been replaced at sometime with a non-appropriate red plastic sheaved one. Putting back together with replacement parts, I now am not sure what the proper cable routing should be. What I’ve read the ground should go to the Ujoint clamshell but is the picture below showing a correct routing? Similar question for the starter switch cable? There was a bracket on the old cable but it was loose and not attached to anything. Where does this attach?
petehoovie 10-06-2023 12:00 PM
Re: Battery Cable Routing for 34
Originally Posted by Abcarswell (Post 2260682)
My brake job has expanded into a replacement of the rotted out battery tray and cables on my Fordor. The ground strap was shot and also attached to one of the battery tray bolts which from what I read is not correct. The cable to the starter switch had been replaced at sometime with a none appropriate red plastic sheaved one. Putting back together with replacement parts, I know am not sure what the proper cable routing should be. What I’ve read the ground should go to the Ujoint clamshell but is the picture below showing a correct routing? Similar question for the starter switch cable? There was a bracket on the old cable but it was loose and not attached to anything. Where does this attach?
https://www.fordbarn.com/forum/attac...7&d=1696609590
https://www.fordbarn.com/forum/attac...8&d=1696609590
Lawrie 10-06-2023 02:53 PM
One thing, Isee that that rear most screw retain ng the ftransmission cover is a long one and sticks through.It is supposed to be a short one,
all the others are long ones.well they are in my 33 and 34 .
Lawrie
Terry,OH 10-07-2023 08:08 AM
The cap covering the U-joint should have an extra ear with a tapped hole that the ground attaches to with a bolt and lock washer. The ear should be where your ground cable is attached Upper left rear view. The insulated battery cable attaches to the foot start switch and runs over the top of the engine bell housing then down to the starter. There are two rubber insulated brackets, as you question, that hold the cable above the bell housing using the bolts that hold the transmission to the bellhousing.
Abcarswell 10-09-2023 03:55 PM
The extra ear as you described was there and that is what I have attached the strap to. The cable from the switch to the starter was properly positioned with the two brackets. It appears to be original. The cable from the switch to the battery is the one I’m struggling with as it also had a bracket which was not attached to anything.
