The Ford Barn
-   Late V8 (1954+) (https://www.fordbarn.com/forum/forumdisplay.php?f=5)
-   -   1961 ford power steering install (https://www.fordbarn.com/forum/showthread.php?t=331400)
Indomwe 09-27-2023 09:01 AM
I am trying to install Borgeson power steering on my 61 fairlane with column shift. Apparently there is a modification to the bottom of the column and column shifter linkage that can be done to allow the installation of the rag joint. I am looking for advice on how what needs to be done
Thanks
Nick
miker98038 09-27-2023 06:00 PM
Re: 1961 ford power steering install
Since I don’t know how the 61 steering is laid out, I’m not sure I understand the question. On earlier cars (with the 1 piece shaft from the box to the wheel), you’d be cutting the jacket, cutting the shaft and fitting a bearing at the bottom of the jacket for support, then using probably DD fittings to convert to the spline necessary for the rag joint. Maybe a short section of shaft also. Most of those parts would be available if not from Borgenson from Ididit or Flaming River. Then a floorboard mount to stabilize the jacket going thru the floor/toe board.
This close, or am I completely off base?
Indomwe 09-28-2023 01:20 AM
The 61 standard column with Column shifter has to be modified to fit a rag joint. Between the borgeson power steering box there is only 1.5 inches to the shift linkage and with the rag joint we need about 3 inches. According to borgeson there is a modification that can be done and another guy on the HAMb has done this but I have not been able to find out exactly how this modification is done. I am wondering if anyone else on ford barn has experience and can help
Dave V 09-28-2023 06:27 AM
I was just researched the same issue recently for my 56 and discovered that the rag joint is not necessary. Can't remember which vendor I found has a coupler which joins the Borgeson box to the steering shaft keeping it inside of the column and allowing your column shifter
Indomwe 09-28-2023 06:31 AM
Yeah I have a coupler but the alignment with no movement that the rag joint allows has the steering box squealing like crazy.only way I know how to fix it is somehow get a rag joint installed ?? I am sort of stuck right now ��
cos 09-28-2023 08:13 AM
Maybe go over to 1957 ford forum, there is info on this. Steering box should not squeal, rag joint probably would not cure problem. Thinking flexible joints helps with vibration mostly and are safer. Cos
miker98038 09-28-2023 07:18 PM
Did you really have to reef the column back in place after you put the coupler in? I’m not an operating engineer or anything with tons of hydraulic experience, but squealing on pump and tractor hydraulics has always been air in the system, or the rpm set too low on the PTO causing a pressure problem. Mostly air.
fordor41 10-06-2023 11:22 PM
same problem I have with my '60. If you shorten the column enough to install a rag joint, the shifter shaft and linkage and NSS if you have a column mounted switch, will have to be moved up an equal am't. May turn into a can of worms.
KULTULZ 10-07-2023 01:19 AM
I hesitate to do this, but ...
https://www.borgeson.com/steering-sy...esign-and-tech
... there, I have done it. I feel so cheap and tawdry. I need a shower ... :(
