The Ford Barn
-   -   Vicky rear garnish moldings (https://www.fordbarn.com/forum/showthread.php?t=330451)
Weaponsusmc 09-01-2023 10:42 PM
I have a 31 Victoria that's missing the rear garnish molding, does any other A rear molding fit?
Phil Brown 09-01-2023 11:30 PM
Re: Vicky rear garnish moldings
I believe that there unique to that body style
But just saw these https://www.ebay.com/itm/16604551864...mis&media=COPY
Weaponsusmc 09-02-2023 07:11 AM
Thank you Phil, just need the back window.
Phil Brown 09-02-2023 10:07 AM
:) the very back window just might be the same as some other models but I just dont know for sure
Oldbluoval 09-02-2023 02:55 PM
Back window frame same in slant fordor
Bill Cilker 09-02-2023 06:16 PM
Technically speaking there are 2 slightly different rear window frames for a Victoria. There is one for a Leatherback and one for a Steelback. When I compared the two side by side, the only difference was that the opening on the wood side of the frame was slightly wider on the SB frame. I have not compared the SW sedan rear frame with a Victoria frame, but they are both 26" wide windows so they might be interchangeable as Oldbluoval says.
Oldbluoval 09-02-2023 06:43 PM
Bill…
Good point on steel back and leatherback.
Not familiar with leatherbacks much.
Bob Bidonde 09-03-2023 09:03 AM
Bill, your comment re the back window frame is good stuff for The Bustle. Thanks for posting.
Weaponsusmc 09-03-2023 09:33 PM
Thanks for all the information, nothing was adding up with my Vicky rear window, its 28 inches give or take. I called the fellow asked the previous owner, said the guy before him put a 50 ford pickup rear window in it.
