Lincoln Gear Cluster Years ago one could buy the Lincoln gear cluster that fit the 1940 vintage tranny's and had a higher gear ratio in first gear. I think MAC or someone sold them. Are they reproduced ?
Re: Lincoln Gear Cluster |
Re: Lincoln Gear Cluster You have to buy THREE gears - the complete set --> The main input, the cluster and 2nd gear (they all go together).
Re: Lincoln Gear Cluster Thanks ! It would be nice if all the forward gears were synchromeshed.
Re: Lincoln Gear Cluster Tell us about your application that you are planning to use the LZ gears on. Details like car weight, rear axle ratio, tire size and engine size and modifications would be helpful for discussion.
Re: Lincoln Gear Cluster Quote:
