The Ford Barn
-   -   Front brake shaft Housing nut (https://www.fordbarn.com/forum/showthread.php?t=330046)
sequim 08-21-2023 10:11 PM
My friend has a early 30 Model A coupe and at a car show this weekend, he realized the nut is missing on the backside of the front brake shaft housing (spring perch area). Not the bottom castle nut, but the standard nut and washer as shown on judging pages 7-5. Earlier versions seem to indicate a castle nut 7/16 - 20, which happens to be same nut as a head nut (just not grade 8). Yet a brand new head nut won't thread onto my early 30.
Hate forcing something so asking folks is this the right thread? I don't see the nut advertised on Model A suppliers other than a castle nut. Head nut comes up all the time when doing the search and physical outside dimensions are the same as original missing nut. Part number in a 1930 book is A-21793-S1
Thanks
Y-Blockhead 08-21-2023 11:42 PM
Re: Front brake shaft Housing nut
According to Bratton's catalog it is a 7/16" - 20. https://www.brattons.com/30-31-FRONT...ductinfo/2960/
john charlton 08-22-2023 01:34 AM
The actuator shaft can be removed without turning the king pin . This can sometimes "wipe" the thread on one side . Normally the nut will thread back on could be the thread is damaged so run a die nut down to clean up the thread . Just a thought .
John in sunny Suffolk County England .
sequim 08-22-2023 10:08 AM
Thanks both of you. Could not find the brattons plain nuts as shown on the first reply and the nicked threads likely the issue.
