39 Deluxe hood support I’m ready to install my hood and uncertain about the hood support arms. ( repro) the top is obvious but where do the bottoms bolt to? I know it’s to the cowl but I only see one hole where the arm has two holes on bottom that seem quite small(3/16). What size bolts are correct? If anyone can post a picture of this, I would greatly appreciate it. Mark
Re: 39 Deluxe hood support 2 Attachment(s)
Mark, The repop supports are not correct.
Photos attached... |
Re: 39 Deluxe hood support Would taking off the bottom bracket with the two holes work?
Re: 39 Deluxe hood support Marko, Please post clear photos of the hinges you are trying to use. Are the attachment points for the hood hinges and the cowl the same for 39 and 40?
"Kube": I am curious as to what that little stamped metal tag on the firewall above the grommet where the wiring harness passes through "says" as I have never seen that before on a 40 Ford.. Thanks, JIM |
Re: 39 Deluxe hood support 3 Attachment(s)
Pictures of a 39’ Deluxe for orientation.
Hardware most not likely politically correct around here . Hope they help you. Attachment 519537 Attachment 519538 Attachment 519539 |
Re: 39 Deluxe hood support Quote:
https://www.fordbarn.com/forum/attac...8&d=1687986853 https://www.fordbarn.com/forum/attac...9&d=1687986853 |
Re: 39 Deluxe hood support Mark, likely you have a pair of supports for the 1940 cars. The tab with two holes bolted to the firewall with the pivot being "about" the same location as the hole for the pivot bolt in the 1939 firewall.
I think you would be OK removing the pivot bracket from the ones you have, or drilling the firewall and mounting the ones you have 1940 style. Mock it up by clamping in place and making sure everything works first. |
Re: 39 Deluxe hood support https://www.fordbarn.com/forum/attac...p;d=1688001497
1939 Ford Deluxe showing hood support brackets |
Re: 39 Deluxe hood support A quick update, the 40 supports will not work on the 39 as the bracket that bolts to the cowl is wrong. I removed one bracket and it looks like it will work now however I am trying to get hood alignment first. Problem is gap at cowl. The one side is 1/4” and the other is 1/2”. Any suggestions on correcting this will be appreciated. Mark The alignment at the belt line is ok.
Most likely you will need to remove the hinge and slot the hole in the cowl as well as the two small holes in the hinge. You may already have figured out the geometry of these hinges but just in case... rotating the hinge upwards, will bring the hood down. Rotate it down? The hood will move up. |
I would only adjust one side at a time. The 1/4" gap side... if you are okay with that, then yes, it's "good". Drake hinges tend to be very tight. If and when you remove them, I'd strongly advise you move the levers back and forth until they move freely. Binding, as they most often do out of the box, will cause some fitment issues. |
