The Ford Barn
-   -   Had a flat today (https://www.fordbarn.com/forum/showthread.php?t=327610)
Billy 1931 Model A 06-12-2023 08:54 PM
Had a flat today
The stem popped off. With some help from a bystander, we were back on the road with the spare in minutes. I guess I can buy a 4.75/5.00 X 19 tube from Coker Tire.
What's the proper psi inflation for these tires? Mine are whitewalls.
Thanks, Billy
katy 06-12-2023 08:59 PM
Re: Had a flat today
Thanks, Billy
Same as the blackwalls, 30 PSI.
TerryO 06-12-2023 09:09 PM
I run 35 PSI in both bias and radials.
TOB
Synchro909 06-12-2023 09:34 PM
When I run 35 psi, the ride is hard but the car doesn't wander all over the place. When I run 30 psi, the ride is softer but the car is "squishy" on the road.
With good, well lubricated springs, I prefer 35 psi.
Y-Blockhead 06-12-2023 11:37 PM
35 psig cold.
Ray in La Mesa 06-13-2023 08:32 AM
There are replacement patch stems available to replace your broken off stem, works just like a regular patch & saves a tube.
Charlie Stephens 06-13-2023 12:31 PM
Do a little research. On of the suppliers (probably Bratton's) started producing high quality tubes. Of course they were more expensive. They have probably become common throughout the industry but I don't know.
Charlie Stephens
Synchro909 06-13-2023 08:50 PM
Charlie Stephens
IMO, if a tube is say, $20 and it is unusable rubbish, it is expensive. You paid $20 and got nothing. A tube at $40 might seem expensive but it will likely last years. For your $40, you get years of service, making it a far cheaper option than $20 for nothing. By the time the $40 tube is thrown away, the price will have been forgotten.
About 10 years ago, someone thought it was a good idea to use recycled material to make tubes. It wasn't. It was then when everybody was having trouble that (I think you're right) Brattons had some made with virgin materials. They were much better. The only tubes we can buy here now are Chinese yet seem to be OK so far.
