12volt conversion Protronix and lower fan pulley Hi folks,
Well, I got my Protronix distributor in today and it won’t fit with the outer lower fan pulley, is anybody solve this problem? |
Re: 12volt conversion Protronix and lower fan pulley Get rid of the Pertronics
Re: 12volt conversion Protronix and lower fan pulley Quote:
Not a fan of their stuff. Wasn’t a fan when their US-made stuff died on me (more than once) in the 80’s when they were Perlux. Undoubtedly, they’re probably even cheaper these days, so even worse in reliability. |
Re: 12volt conversion Protronix and lower fan pulley Hey guys that's not what he asked or wanted to hear!! I have three vehicles with Pertronix and they have all operated perfectly. I went to that unit because I had NEW points that literally came apart and left me stranded. Sorry Will............
Re: 12volt conversion Protronix and lower fan pulley Could use more details like is it the crab style? They appear to be really tall. A photo would also help.
Re: 12volt conversion Protronix and lower fan pulley Are you running a generator? Electronic distributors don't like the voltage variations the output of a generator makes. I have never seen NOS points fail in the way you describe.
Re: 12volt conversion Protronix and lower fan pulley Ran a Pertronix for a few years, used their coil and wires as well. No problems.
Condensers failed that left me stranded in the Santa Cruz mountains. |
Re: 12volt conversion Protronix and lower fan pulley Sweet
Re: 12volt conversion Protronix and lower fan pulley Need more info. Petronix module in a stock dizzy should work without issue. What set up are you using?
Re: 12volt conversion Protronix and lower fan pulley Hi guys, NEW Question and thank you for all your input. I do appreciate it and I don’t get offended at whether I should do one thing or the other I’ve seen people using different set ups. I did get the pulley off and the distributor on.
When I’m sliding the pulley back in. On the keyway it only goes part way. It’s not hitting the Distributor. The pulley is actually hitting something within the channel that is preventing me from sliding it all the way back, do I need to put the truck in neutral and try turning it in order to get the collar to slide all the way back? I’m not sure what the procedure is to putting that pulley back on.. |
Re: 12volt conversion Protronix and lower fan pulley There should be a key in the crankshaft and a slot in the pulley that need to align.
Re: 12volt conversion Protronix and lower fan pulley 2 Attachment(s)
That’s right, it goes on the key way but it won’t go on enough to catch a thread.
I included the previous picture before changing out the distributor. And the current look with the keyway. |
https://www.fordbarn.com/forum/attac...9&d=1686411485 |
Let's just help him get his pulley back on.:) |
Re: 12volt conversion Protronix and lower fan pulley Thank you, I agree. Just looking for some help.
Re: 12volt conversion Protronix and lower fan pulley 1 Attachment(s)
OK guys, I needed a pulley insert tool and that just cranked it right on O’Reillys that your rent them for free.
Next question for those who have done the conversion. My distributor sticks out a little bit over the fan pulley, see the picture, what did you do to overcome this obstacle? I’m gonna try a longer fan belt because the fan pulley lays right on top of my coil plug. |
Re: 12volt conversion Protronix and lower fan pulley Regarding the pulley: Is the woodruff key loose in the slot on the crank? If so, sometimes they move around a bit which prevents the pulley from seating fulling. If not, look at the female slot on the pulley to see if there is any damage, etc that is preventing it from seating.
Not sure if you tried this, but I would take off the distributor while working on the pulley so you can see clearly what is going on. Regarding the distributor: This looks like the one you got. https://www.speedwaymotors.com/1942-...BoCggcQAvD_BwE It is absolutely longer and larger than a stock unit. Petronix makes a module that fits inside a stock crab distributor. Using their module inside a stock crab distributor housing will cure your pulley clearance issue. |
