First T '25 cpe w original engine-runs/drives Hydralic rear brakes!! 1 Attachment(s)
Where to start- my first plastic model was the AMT '25 T cpe so after 40yrs I finally got a good solid example. Eng no. is 11,***,*** Photo here. It has some kind of aftermarket disc brakes on the rear. 12V alternator correctly mounted.
Check out the Hydraulic DISC rear brakes!! Newc |
Re: First T '25 cpe w original engine-runs/drives I like it, and now you have me intrigued about the brakes.
Re: First T '25 cpe w original engine-runs/drives Found that the rear drums have large disc rotors welded to the drums and hydraulic Wilwood calipers are mounted to the rear housings. Brake cyl is mounted to a pedal? work fantastic will explore it more, and photos some day. Newc
Re: First T '25 cpe w original engine-runs/drives https://www.fordbarn.com/forum/attac...p;d=1684205632
Newc's one to one scale 1925 Ford Model T Coupe - Neat |
Re: First T '25 cpe w original engine-runs/drives 3 Attachment(s)
Photos of the cpe rear hydraulic DISC brakes- looks like a kit !!
Re: First T '25 cpe w original engine-runs/drives Hydralic rear brakes!! Looks like currently made Surstop disk brake setup: https://www.modeltford.com/item/2565.aspx
Re: First T '25 cpe w original engine-runs/drives Hydralic rear brakes!! Double post.
