Hub cap spinning light bulbs Maybe 60 yrs ago my father made a little hot roders modification to one of his hub caps on the 34.
I guess it was popular at the time? They still worked until I bumped it doing an oil change. I'm in need of an old bulb socket that has snapped. To make it difficult the back side of the socket is threaded. It is pot metal so I can't solder. I doubt there would be enough meat to jb weld either. I'll attach pictures....or not file error? |
Re: Hub cap spinning light bulbs 4 Attachment(s)
Re: Hub cap spinning light bulbs Quote:
Re: Hub cap spinning light bulbs Yes, last summer.
Have a case of CRS. I'm working in it. Tks |
Re: Hub cap spinning light bulbs Pics ready
https://www.fordbarn.com/forum/attac...3&d=1683565009 https://www.fordbarn.com/forum/attac...4&d=1683565009 https://www.fordbarn.com/forum/attac...5&d=1683565009 |
Re: Hub cap spinning light bulbs Maybe try JB weld?
Red |
Re: Hub cap spinning light bulbs |
Re: Hub cap spinning light bulbs "Muggy-Weld"? I've tried it twice; worked great the first time, not at all the next. I think it depends on the alloy of the metal you're repairing.
Re: Hub cap spinning light bulbs Find something tubular to act as a band, JB weld in on being sure the bulb notches stay clear, and maybe shorten the bulb pegs a bit if needed.
How does the electric part of that set-up work? |
Re: Hub cap spinning light bulbs Restoration Supply Company Page 8 item ELE067.
https://restorationstuff.com/shop/ |
Re: Hub cap spinning light bulbs That must have a connection like a horn button. Allows it to turn and have an electrical contact. That must look like a circle of light at night when the car is moving. I put small lights on the king pin caps of a Peterbilt I used to run. It looked like a circle of light behind the wheel going down the road at night........Mark
Here are some pics of the wiring and brush on the wheel/ break drum. Wired to a switch under the dash. Dad did this back in the late 50's.
Re: Hub cap spinning light bulbs Bob C. Nope that won't work.
Thank you. |
Re: Hub cap spinning light bulbs Terry,
Very clever idea. I would just replace it with a new bulb and socket. It’s not like it’s original equipment. Richard |
Re: Hub cap spinning light bulbs My head is hurting trying to imagine out how the electrical supply gets into the space behind the hup cap!
Did you look at the pictures in post #13? |
Re: Hub cap spinning light bulbs Duplicate post. Sorry.
