The Ford Barn
-   -   Valve spring removal with heads on possible?? (https://www.fordbarn.com/forum/showthread.php?t=325430)
tetanus 04-10-2023 06:08 PM
Have not tried yet figuring I would ask the pros before I try to wrestle them out. It’s a 59 block with mushroom stem valves and 185 isky springs.was wondering if I can get springs out of there without pulling heads?
Jack E/NJ 04-10-2023 06:43 PM
Re: Valve spring removal with heads on possible??
Maybe. But pull the heads anyway. 8^)
cadillac512 04-10-2023 08:52 PM
Unless the camshaft and lifters are removed to allow the springs down the lifter bores, I don't see how it will work. Just not enough room.
Terry
