The Ford Barn
-   -   1933 ford pu gas tank (https://www.fordbarn.com/forum/showthread.php?t=325118)
ronn 04-02-2023 07:38 AM
tank is rotted out and Ild like to place a tank in the front of the bed.
Is that enough height for gravity feed or do I need to install a fuel pump?
rotorwrench 04-02-2023 09:27 AM
Re: 1933 ford pu gas tank
It's doubtful that a tank that is level with or below the carburetor will have any gravity flow. The B engine and all of the V8 engines were set up for a fuel pump. If mechanical won't work then use an electric one. A fuel pressure regulator may be needed depending on the carburetor and type of pump in use.
katy 04-02-2023 10:14 AM
Where is the original tank located?
Floats 04-02-2023 10:31 AM
The tank on the pickup is above the drivers knees. The cowl, instrument panel and part of the fire wall is the fuel tank, with the filler cap and the wind screen on top.
Sadly, a very dangerous position if you are in a serious accident.
Regards
Chris
Jim Brierley 04-02-2023 12:21 PM
1932 Ford pickups have the tank under the drivers seat, and I assume the '33-'34 pickups do too. Are you sure you don't have a Model A pickup? If so, the tank might gravity feed a stock carb, but a pump should be used with a downdraft carb.
ronn 04-02-2023 04:15 PM
ITS A 33 FORD PU- TANK IS LOCATED ALL THE WAY BACK ON THE FRAME RAILS- WELL NOT ANYMORE. i REMOVED IT THIS AFTERNOON.
sorry about the caps- stuck
anyway it is a 33 and not under the seat, as in the 32. this sits on the frame rail as does
my 39 panel. I thought with the bed being elevated, it might flow down to the carb. maybe not?
Bob C 04-02-2023 06:08 PM
Don't you have a fuel pump?
the.secret.victoria 04-04-2023 09:15 PM
That only applies to the Model T and A. The later years placed the tank elsewhere.
Originally Posted by ronn (Post 2215888)
ITS A 33 FORD PU- TANK IS LOCATED ALL THE WAY BACK ON THE FRAME RAILS...
...I thought with the bed being elevated, it might flow down to the carb. maybe not?
The V8 era cars aren't gravity feed; they rely on a mechanical fuel pump that's mounted at the rear of the intake manifold to suck fuel out of the tank. You won't get any sort of gravity feed action with the tank level below the carburetor.
ronn 04-05-2023 04:00 AM
thanks folks. appreciate the input.
katy 04-05-2023 09:59 AM
What engine is in that '33?
ronn 04-05-2023 03:56 PM
v-8
