36 ford spark plugs What are the best plugs for a stock V-8. I assume hotter is better?
Re: 36 ford spark plugs There are a couple of different heads for the 36 that take two different size plugs. Which heads do you have? Part number should be embossed on the head.
Re: 36 ford spark plugs My heads are cast iron for flat top pistons. Takes a plug that fits a 7/8 wrench.
Re: 36 ford spark plugs I use Champion UD16. Have for years.
Re: 36 ford spark plugs What is the "plug De Jour" for stock with pop-ups??
Re: 36 ford spark plugs Robert I use UD16 in my 36LB with dome pistons. Stock engine.
Re: 36 ford spark plugs Thank you Tony!!
