1953 eac mercury engine value I am looking at buying a complete core EAC engine for a project. The engine is a take out from a 1952 f-1 with a heavy duty 4 speed bolted to it. It is complete from fan to u-joint with merc carb. dist. starter, fuel pump, exhaust manifolds ect. Engine is not locked up it turns by hand. What would you estimate a fair price would be to pay for this engine? Thank you for any help!
Re: 1953 eac mercury engine value Unless you can hear it run and check the oil pressure while running, not much. Complete cores have gone up in recent years, but I wouldn't pay more than $200 for a motor of unknown condition.
If you do pay more, insist on a money back guarantee that, if it turns out to be cracked, you'll get your money back. If you haven't done it before, tearing down a flathead is a labor intensive job. Having some flathead specific tools helps tremendously. Sometimes it just comes down to torching, pounding, and a lot of cursing to get them apart. |
Re: 1953 eac mercury engine value Tim is correct. Before buying, you should be allowed to re move the heads to check the stroke and also the block for cracks. Pull the intake also. Doing so would also benefit the seller. Remember, that engine is 70 years old and has probably endured lots of hard miles, especially if it was in a truck.
Re: 1953 eac mercury engine value I would be reluctant to buying any used motor unless the heads are off so you can inspect for cracks in the valve seats and in the cylinder walls.
Re: 1953 eac mercury engine value Quote:
Re: 1953 eac mercury engine value All good advice, but if it is a Mercury, and turns and looks good, I'd offer $400 (the crank alone is worth that), and might go as high as $600 if it looks to have never been stored outside.
You might get lucky. I bought an unknown '51 Merc about 25 years ago for $400, and it ran so well that all I did was clean it up, re-gasket it, and paint it. I'm still running it. Other than excessive oil consumption when running at 65+, it still runs good and strong. |
Re: 1953 eac mercury engine value 1 Attachment(s)
Picture of engine.
Re: 1953 eac mercury engine value 2 Attachment(s)
Pictures
Re: 1953 eac mercury engine value Do you have access to this engine or are you buying it sight unseen? If sight unseen, max $200 since it's confirmed it has a 4" crank.
If going to see it in person, bring a wire brush and brush away the carbon around all the valves. Bring a high power LED flashlight and look closely for cracks from the valves to the cylinder bores. Brush off one of the pistons to see if there is an oversized stamped into the piston dome. This will tell you whether or not it's ever been rebuilt. If you don't see well, bring a magnifying glass. Most cracks can be seen if you know what to look for. I would suggest tearing this block down regardless and cleaning it properly. From what I can see, there is a lot of crud in the water jackets. Judging by the poor quality of the picts, I'm making the assumption that it will need to be rebuilt. The bores look past just a hone and re-ring, but this is a big assumption just going off the posted picts. |
Re: 1953 eac mercury engine value I have to disagree Tim. It's obviously a Mercury and when I looked closely, I don't see even any "part number" cracks. In my experience (probably 10+ engines), every one without those cracks turned out to be crack free.
I'd start at $500 and might even go higher. Have you priced 4-bolt Merc intakes lately? |
Please don't tell me 4 bolt intakes are commanding a decent price. I just scrapped 3 of them. What's the going rate? |
Re: 1953 eac mercury engine value Since it has a Merc crank - you can think of that as worth about $400 - the intake is probably worth $50 or maybe more to the right guy.
So, if you can do what Tim mentioned and can clean the block areas between the valves and the bores (looking for cracks) and also pull the pan and look for pan-rail cracks (which are fatal), then you'll know that your $500 bet is probably going to be worth it. I would take a drill with a wire brush on it and some lacquer thinner to clean all the valve to bore areas, then with a good light and magnifying glass, you can usually spot obvious cracks. From experience, I seem to see more 49-53 cracked blocks than the earlier ones. This may be due to the fact that the cars were bigger, had more "accessories" on them and tended to run hotter in the later years. That is just my hunch . . . |
Re: 1953 eac mercury engine value Tubman forgive me for not understanding but what do you mean by "part number cracks"?
Re: 1953 eac mercury engine value Yep. I paid $50 for an iron one at a swap meet last year that had a chip out of the fuel pump base it didn't effect the integrity, so I fixed it with a high quality epoxy and painted it. It is undetectable. I don't even want to think about the aluminum Canadian versions. I looked for a long time for one and paid $100 about 10 years ago. I think this is partially my fault, with my championing of 2G's on these cars.
I have had better luck with Mercury blocks than Fords. I attribute this to better cars, better owners, and better radiators. |
Sorry for being so "technical".:D |
Re: 1953 eac mercury engine value Just got back from looking at the engine its definitely a Merc, standard bore,i cleaned the areas around the valves to bores and could not see any cracks on each bank, it rotates and every thing moves. It was stored outside with the upper water necks and thermostates removed, the water jackets are very rusty and so is the rest of the block and accessories. The seller is holding FIRM at $1000 and would not budge on price, so i walked away. I told him if he changes his mind to let me know. Thank you for all that chimed in .
Re: 1953 eac mercury engine value You might regret your decision, but it was yours to make. Let's hope he gets back to you.
Re: 1953 eac mercury engine value If you had the pan off , I would also remove at least one rod cap and one main cap and ck to see if the crank had already been turned, and if so how far.
Re: 1953 eac mercury engine value I would have no regrets from walking away, at that price and what you describe. There are still many out there.
Re: 1953 eac mercury engine value At a grand I would have walked away too.
