30-31 Open cab pickup wood Anyone have any pictures or diagrams of how the wood is installed.All the vendors and wood people don't show anything. Bunch of wood came with the truck. Trying to figure the puzzle. Thanks for any help. Lee
Re: 30-31 Open cab pickup wood This help
Re: 30-31 Open cab pickup wood When I did my 31 open cab P/U, I bought a woodkit from Bert's. I received 6 pieces of wood. 3 were for cab back braces (all the same). 2 pieces that fit where the door latch and dove tail attach to. The last piece runs in the seat raiser. Hope this helps.
Re: 30-31 Open cab pickup wood Quote:
Warren |
Re: 30-31 Open cab pickup wood Thanks for the help. A picture of the seat back wood if possible would be great.
Re: 30-31 Open cab pickup wood It should be self explanatory.Find the three that fit between the bolt holes in the back of the cab and the lip on the seat riser.Are you thinking there is wood on the back of the set spring? If so,there isn't any wood there.
Re: 30-31 Open cab pickup wood I was wondering if there is any interior belt rail wood that goes inside the cab for the top fasteners to screw into or do they just attach to the body. I know there is no wood on the seat back.I have seen plenty of 28-29,s but never a 30-31 in person.
Re: 30-31 Open cab pickup wood No Belt wood on a 30-31 cab. I got some machine threaded fasteners and used lock washer a nut to hold them.
Re: 30-31 Open cab pickup wood I used the sheet metal screw type of fasteners,but a couple of them loosened up.I should have used the bolt type.I intended to change them all over,but just used some sheet metal screw clips to get by.That was about 18 years ago,and I kind of forgot about it.
Re: 30-31 Open cab pickup wood Thanks to all.
Re: 30-31 Open cab pickup wood 4 Attachment(s)
Charlie Stephens |
Re: 30-31 Open cab pickup wood Thanks Charlie, that is a big help. I think all the wood that was piled in the truck was for other cars. Lee
Charlie Stephens |
