The Ford Barn
-   -   40 front bumper (https://www.fordbarn.com/forum/showthread.php?t=32338)
okiedokie 03-25-2011 09:06 AM
40 front bumper
Went to install my front bumper today, I find that the brackets [new Drake style] are incorrect for the bumper, [Drake bumper]. The holes in the brackets are about 2 1/2" closer together [inner and outer brackets] than the holes in the bumper. The rear is fine. I have a std so ordered the std brackets, but bumpers are same. What am I missing here?
dirtcop47 03-25-2011 09:10 AM
Re: 40 front bumper
I just installed my 'Drake' front and rear bumpers on my 1940 Ford coupe. In both cases the outside holes lined up nicely, but the inner brackets had to be pushed into position. I also had a 1939 bumper where the holes are lined up differently than a '40' Ford. Be sure that the brackets sent are correct for the 40 Ford.
Lawson Cox 03-25-2011 09:31 AM
Re: 40 front bumper
Typical.
okiedokie 03-25-2011 10:39 AM
Re: 40 front bumper
Well, after deciding I was gonna make it fit, pushing, pulling, prying and prayin, it's on. If anyone backs into me they will be propelled away at an alarming rate, lol. The back just lines up and bolts on. I have heard that deluxe and standard's use different brackets because of the grill, maybe that is the reason for the hard fit???? I know that Lawson feels that it should all fit like rear bumper, but I am just tickled to be able to buy the parts. It seemed like it would never come together, but it is.
296 V8 03-26-2011 09:52 AM
Re: 40 front bumper
Standard bumper irons only bring the bumper in closer to the grill than deluxe because the deluxe grill sticks out further.
Are you sure you are installing them correctly?
If I remember
The inner ones go on the inside of the frame horn …. Outers on the outside….yes?
redfor40 03-26-2011 02:19 PM
Re: 40 front bumper
thats how i got mine to fit pushing prying and pulling
OLD...BILL 03-26-2011 02:50 PM
Re: 40 front bumper
296: is right,at least 39 deluxe front bumper is that way he said. The inner brace is bolted to inside of frame. and the outer is to outer frams side, using the same bolts, through the frame, hope tgis helps.... OLD....BILL
okiedokie 03-26-2011 03:11 PM
Re: 40 front bumper
That is correct, brackets sandwhich the frame. Spoke with a local guy who recently installed front bumper with same difficulties. Don't know if it is bumper or brackets, but something seems to be not quite right. Just glad I got them installed and the back was a cinch. Since the rear bumper fit so nicely, I'm guessing it is front brackets causing the problem.
BobM 03-26-2011 07:50 PM
Re: 40 front bumper
Went thru the same thing with the front bumper on my '36; rear ones matched up perfectly.
TJ 03-27-2011 10:47 AM
Re: 40 front bumper
I used the new Drake brackets with repo bumpers on my 40 Standard and they fit fine on both front and back.
kwmpa 03-27-2011 02:58 PM
Re: 40 front bumper
X2 my bumpers bolted right up and together in about 15 minutes.... ive never had a single problem with any dake product....top quality in my book everything alwaysfits as it should.....i just used his cowl sides floor pans and subrails they were the best fittinf patchs i have ever used hands down....i dont get all the bitching and whining about bob drake like it was stated befoe just be glad someone is making the parts
