8ba road draft Inner tube removal Hi guys:
What is the best way to remove the inner part of the road draft tube (in the valley)??. I tried grabbing it with vice grips, it doesn't seem to want to move. Thanks in Advance, Dave |
Re: 8ba road draft Inner tube removal Heat around the bottom of it with propane torch.
Re: 8ba road draft Inner tube removal Stick a piece of wood inside it and wiggle it. Something that’s round and a little smaller.
Re: 8ba road draft Inner tube removal Just wiggle it a bit side to side it will come out. I usually put a vise grip on that tube when I find its a bit stubborn to remove and then use some side to side force. Once its out I simply tap the now some what flat area round again where the vise grip once sat.
Ronnieroadster |
Re: 8ba road draft Inner tube removal Great- thanks for the suggestions guys, ill give it another go!
Re: 8ba road draft Inner tube removal I inserted the handle end of a large screwdriver into the tube .
Wiggled it back and forth a few times,,,,,it came right out,,,,,,no damage at all . Tommy |
