The Ford Barn
-   -   37-41 inner distributor caps (https://www.fordbarn.com/forum/showthread.php?t=320734)
Lawson Cox 11-23-2022 04:08 PM
I need a set of used 37-41 inner distributor caps for the display engine I'm building. Do not be in working order, just so they fit correctly. What do you have.. This is running on the swap meet as well. I'm in somewhat of a squeeze here. Thanks guys/gals. Lawson
DavidG 11-23-2022 06:43 PM
Re: 37-41 inner distributor caps
Lawson,
Thinking back over your posts regarding this project of yours, wouldn't it be helpful to you and to those who may have the needed parts to think ahead and post a more comprehensive list rather than the one-at-time approach that you have been using?
Ken/Alabama 11-23-2022 07:30 PM
Hey Lawson, I probably got what you need. I’ll look around after the Holiday.
Lawson Cox 11-23-2022 08:53 PM
Originally Posted by DavidG (Post 2183571)
Lawson,
Yes, David, it would have been simpler had I been gifted with clairvoyance, but alas, I can only take things as they come up or I screw up.
I have only restored 4 vehicles to your multitudes, and nowhere close to the same degree of perfection as have you. You are a true master of this. This is my first true venture into truly detailing engines, period.
Lawson Cox 11-23-2022 09:03 PM
Thanks Ken. Check your private messages.
