Starting Issues I know it’s my fault - left my restored 1930 Model A sitting for 6 years without pickling the engine. Lots of rust in the tank and carburetor clogged. Spent the weekend rebuilding the carb and cleaning all the gunk out. Used a rebuild kit to replace all the jets.
Checked distributor; coil is firing, producing spark, points working. Engine won’t fire. How do I tell if the gas vapor is actually reaching the cylinders? Spark plugs may be frozen; hints on how to remove them? |
Re: Starting Issues Don't worry about the plugs being stuck in the head till you prove they are, then come back. Assuming the plugs will come out, try starting it (full choke till it fires) and if unsuccessful, remove the plugs and see if they are wet with fuel. If they are, you are on the way. If not, dribble a SMALL amount (several drops) of fuel down the plug holes and try again. It should fire at least but may not continue to run.
If the plugs are seized, try soaking them overnight with a penetrating lubricant, then use a bigger spanner. I use a ring spanner and I'm not afraid to give it a fair grunt. There is no point trying any of this unless you have replaced the fuel. 6 years old fuel is waaaay past its use by. |
Re: Starting Issues Once the plugs are out consider doing a compression check to ensure no valves are stuck. Adding Marvel Mystery Oil to the gas (4 oz per tank full) would be helpful.
Re: Starting Issues Quote:
Re: Starting Issues Check your timing. You could be firing completely out of phase.
Re: Starting Issues How to tell if your getting gas vapors into the cylinder’s, what goes in must come out, smell the tail pipe!
Re: Starting Issues Turn the engine over w/the hand crank, can you feel the compression on all 4 cylinders?
