The Ford Barn
-   -   1935 Fuel Tank Replace (https://www.fordbarn.com/forum/showthread.php?t=318946)
Dennisfly 10-02-2022 01:19 PM
2 Attachment(s)
I bought the car with an inoperative fuel gauge (water level type) and an old fuel tank. But in a box with the car came a new fuel tank, filler tube, fuel line, serviceable electric 1936 gauge, and a new electric sender that fits the tank. I checked the gauge and sender on the bench and they work.
The question: The old 1935 tank has a vent in the top. The new 1936 does not. Attached are pictures of my fuel cap. which does not appear to be vented. Do I need a vent, and if so, can I do it with a vented cap or is there another way? The Drake catalogue shows the same cap from 1932 to 1948
Lawson Cox 10-02-2022 03:32 PM
Re: 1935 Fuel Tank Replace
Yes, you need a vented cap if you don't have a vent at the tank. 32-48 caps all LOOK the same from the outside. Some are vented, some are not.
TJ 10-02-2022 07:14 PM
Your locking cap is vented via the key slot.
Gary Tosel 10-02-2022 09:42 PM
If your 36 Ford fuel filler pipe is a true 36, the vent is inside at the cap. Small tube around the neck and to the outside of the filler pipe.
Gary Tosel 10-02-2022 09:47 PM
1 Attachment(s)
Photo of 36 Ford filler neck with vent tube.
