tank and fender weltting hi wondering what is the best way to install the weltting around the tank and fenders ?? thanks
Re: tank and fender weltting Notch out the bolt holes in the welting so that when you install it, the welting will pretty much line up and you will be able to get the mounting bolts through. The gas tanks are the most difficult. Try to slide the tank in from the front with the welting and tank together, mounting holes lined up. Good luck.
Re: tank and fender weltting Not only cut bolt holes…
You will need to cut kerfs in the flat. Maybe 1/2 to 2/3 thru at the curves. Particularly at the tank and cowl. Fender welting goes in pretty well without kerfs until you get to the shield union. Also the spacer under the windshield goes on before the tank goes in..makes it a lot easier when you get the knack of it. |
Re: tank and fender weltting I made/installed some pulling tabs on the doubled part of the welting, 6-8 inches apart . The pulling tabs where cloth duct tape. Patient and practice ! practice on the fender welt as it’s much easier!
Re: tank and fender weltting I'm thankful that I have a sewing machine that I can sew on some tabs in key places to help pull the welting into place. Not all installations require this but I can do it in those situations where it is exceedingly difficult. The welt isn't always long enough on the tail part to be able to grasp it well. The original pyroxylin type welt is much easier to install than the vinyl type. It's not as thick in tail and fits much better.
Re: tank and fender weltting 1 Attachment(s)
Here is a picture of the gas tank welt Marco posted some years ago.
Re: tank and fender weltting 5 Attachment(s)
As a side-note, ever wonder why what we buy commercially available is so difficult to work with? Maybe it is because it is not made like Ford made it!! ;) . . |
Re: tank and fender weltting Hello , I thought that “Third Gen “ made some weld that was close to the original?
Re: tank and fender weltting thanks guys for all the good feedback
Re: tank and fender weltting thanks everyone for the great and prompt response
Re: tank and fender weltting About 4 years ago, on a road trip to Wisconsin, I stopped by the late Roy Nacewics’s place in Michigan to pick up some quality hardware. He was out of tank welting and he graciously took the time to run a few yards through his sewing machine for me. I believe at the time he was the only one using the original Ford pyroxylin material for cowl tank and fender welting. Since Third Generation has taken over, I assume they would be using the same original material. It does make a difference.
Re: tank and fender weltting The source for the early style material that the welt was made from came from a company that made hard cover book covers and bindings. The material is a faux leather and is much thinner than vinyl. I've heard that it getting harder to source but Third Gen would be the folks to ask. I could use aircraft grade linen or cotton and coat it with aircraft dope to fill the weave but it would be smooth finish. It can be painted before or after instalation depending on needs.
Re: tank and fender weltting Great info guy's.
I'm needing to replace the tank welting as I get water inside from the corners near the windshield when it rains and when I wash the car. I'll do the roof at the same time probably in November. Regards Bill Regards Bill |
