Brake Adjustment opinion Hi All,
When adjusting the shoe position on early 1940 Ford hydraulic brakes, do you let the shoes drag a little, or back the shoes off until no drag can be heard or felt? What are people using as a best practice? |
Re: Brake Adjustment opinion I let the shoes drag a little. Just a little.
Re: Brake Adjustment opinion Like Jay, I always let the shoes drag just a little bit.
Rub some chalk on the brake shoes and spin the wheel to see high and low spots of where shoes are contacting drum. I also apply 30 pounds of pressure to the brake pedal when adjusting the brakes. I have also read where some folks sand a slight taper on the ends of the brake linings so as to make sure the center of the brake shoes are fully contacting the drum. I have never done this because it seems to me that this would indicate your drums are "out of round". Read about brake adjustment in this thread below. Also, don't forget to adjust your hand brake. https://www.fordbarn.com/forum/showt...st+1940+brakes |
Re: Brake Adjustment opinion One very light and quick swish sound as you spin the drum by hand. Make sure to press the pedal hard a couple times to make sure the shoes and cams are seated if this is a new assembly.
Re: Brake Adjustment opinion There is supposed to be a .005" clearance between the shoe and drum.
Ideally, you will have had the shoes arced to each individual drum for complete contact. |
Re: Brake Adjustment opinion Has anyone ever found a place that you can get shoes arced?
Re: Brake Adjustment opinion Quote:
Arcing shoes was part of every brake job I'd done "back in the day". It was simply a matter of course. A huge difference vs. not arcing the shoes. |
Re: Brake Adjustment opinion to arc shoes you need o/sized linings and as of yet haven't found anyone selling o/size linings quite often if they bond to your shoes to suit cut drums they will be o/sized but o/size linings off the shelf on their own never seen them for these
Oversized shoes are required with oversize drums. Neither of which I would ever consider utilizing. |
Re: Brake Adjustment opinion With respect ,I meant to comment earlier ,Down hear we don't have the luxury of finding new drums most stock linnigs ar 3,1/6 new , so by the time you shave some off to arc you wont have much left ,your best to get over size 1/4 Bonded linings then Arc back ,all your adjustment will then be back to stock .We rarely rivet our linnig's here ,Ted
I don't believe oversize shoes are available in the states. They were outlawed many years ago. Perhaps a brake lining shop would do what you suggest. You are correct of course that when arcing, some lining is removed. |
Re: Brake Adjustment opinion Thank you Kube ,I know you build high quality stuff , Ted
Re: Brake Adjustment opinion I can arc shoes to match drums
Re: Brake Adjustment opinion As a side note, I recall many years ago reading that the OEM thickness of the actual 1940 Ford brake shoe woven lining was .128 in. thick.
Can anyone verify this? |
I can't verify the thickness of woven shoes, but they were not installed as standard equipment on Fords since early 1937. |
