1950 Dana 44 Thrust washer 2 Attachment(s)
Dear community
My friend Yuri broke an axle shaft on his 1950 f1, Dutchman sent us the correct axle shaft, but while checking it all, the 2 thrust washers are broken Can someone sell me that part that I can't find ? Any help would be great Thanks Peter |
Re: 1950 Dana 44 Thrust washer Those don't look like the side gear thrust washers used in the Dana 41 & 44. What rear axle does this pickup have in it?
The axles in the Dana 41/44 are 19-spline types and are held in place in the housing with the locked on bearings bolted in with side plates. The axles don't normally move around since they a splined into the side gears in the differential carrier case. Only the side gears have the 8M-4228 thrust washers and they are pretty large washers by comparison to the photos. They certainly don't look like those in the photos. |
Re: 1950 Dana 44 Thrust washer 1 Attachment(s)
Here is the complete list of parts for 48-50 F-1's. It would be a Dana 41 unless someone has changed it out.
Re: 1950 Dana 44 Thrust washer This is a rear axle from a 1951 F1, axle shaft broke... when openning the rear axle in order to change the shaft, the washers were there, next to the locker unit...
Here is a 1948-52 axle from Van Pelt's site. I only see two washers 8M-4230 3/4" ID 1 21/32" OD and 8M-4228 1 41/64" ID 2 13/16 OD.
Re: 1950 Dana 44 Thrust washer It sounds like someone put a later rear axle in the 51 but it could still be a Dana 44. If it has 19 spline axle shafts then it would be a 1955 or older D44. Lockers can be put in the D44 but those are aftermarket parts. A person would have to find out what unit it has to find parts for the locker set up.
They do look like thrust blocks for a D44 Detroit Locker. They are available from several sources for around $25. A lot of lockers are for the later 30 spline axles. |
