37 - Early 38 Early Distributor Question 1 Attachment(s)
Hey All,
I've torn down the distributor on my newly acquired 37 - early 38 engine and I'm cleaning it up and noticed the #68 part number was crossed off and remarked 11A as shown in the picture. My question is, was there a part number change with the distributor weights, if so when and why? I'm asking because my engine is a 37-early 38, an oddball in some respects. I don't think this engine has seen a car or truck because it was the power supply for a generator. I'm not sure if this engine is just a mashup of leftover parts and made into an industrial engine or if some later parts are involved. I don't need to replace anything other than the Vacuum Brake Plunger, seal, & spring #18-12220 & #18-12205, but I'd like to get as much info as I can before ordering other parts if it comes to that. Regards Bill |
Re: 37 - Early 38 Early Distributor Question The 11A (from 1941) pieces replaced the 68 pieces from 1936. The 11A are slightly better bringing in advance slightly sooner and a bit more about 2 degrees, so you have the better parts and all that is necessary for the upgrade.
Re: 37 - Early 38 Early Distributor Question Thanks Terry ;)
Regards Bill |
Re: 37 - Early 38 Early Distributor Question Bill,
I agree with Terry re: 11A being an up grade. If you notice however the ramps on the rotor shaft ( those openings that accept the guide pins on the weights) appear to be ground out. You may have jury rigged parts....but it'll run. Charlie ny |
Re: 37 - Early 38 Early Distributor Question I'm thinking the 'obvious' comment.... send it to Charlie... he'll make it right
