Antenna cable ground strap location??? I need sharper minds than mine to find location for radio antenna cable ground.
Here’s what the EFV8 1938-39 book says: This hole should be drilled approximately 3 (inches) above the belt line and in the center of the raised surface in front of the hood ledge. Not sure where that would be…. |
