Generator Belt Part Number I'm having to replace my alternator with the generator. I'll need to change belt length too. All my related pullies are standard -- a generator needs a longer belt than alternator, for my application. What might that part number/length might be -- where can I find this info
Tks Guys |
Re: Generator Belt Part Number It may vary a bit depending on the Timing Gear cover. Later covers held the generator "higher" ostensibly to better clear the coolant pipe.
(Nearby and handy) My spare engine (earlier "lower" timing cover - likely yours) has on it a "Goodyear Hi-Miler 22430" which is a "cog-belt" on the inner side. You may not want this since it's not a "stock" appearance. I have placed next to it two belts which are the more common belt sold by Tam's and these are marked "42-6324" Another thread I elaborate about these belts. https://fordbarn.com/forum/showpost.php?p=1467681 There is some "finesse" necessary to place these apparently 42" "B" section belts. Joe K |
Re: Generator Belt Part Number Quote:
https://www.fordgarage.com/pages/timingcovers.htm Joe K |
Re: Generator Belt Part Number [QUOTE=Joe K;2147587]https://www.fordgarage.com/pages/timingcovers.htm
Joe K THANKS!! Using your pictures, I have the following: A-6019-A. Now, using a generator, what's my belt number/length plz!! You guys are a Treasure! |
