The Ford Barn
-   -   Fuel pumps, push rods and stands 32-53 (https://www.fordbarn.com/forum/showthread.php?t=315175)
36coupe 07-03-2022 06:36 AM
What are the different fuel pumps and what interchanges between them?
How many different push rods are there?
And how many different fuel pump stands?
What combinations work between years?
What issues can you get into mix and matching?
deuce lover 07-03-2022 09:23 AM
Re: Fuel pumps, push rods and stands 32-53
19Fordy 07-03-2022 09:40 AM
A book could be written concerning all the questions you pose.
Do a Fordbarn SEARCH usuing " fuel pump push rod" and lots of info. appears such as this:
https://www.fordbarn.com/forum/showt...+pump+push+rod
DavidG 07-03-2022 10:29 AM
And you left out the starting point, the many different intake manifolds, which dictate pretty much all of the rest.
36coupe 07-03-2022 02:44 PM
That’s what I’m wondering.
I thought there was only short and tall intakes (as in relation to the fuel pump stands)
I also thought there is only 2 different length push rods.
Only 2 different fuel pumps in how they mount to the stand.
2 different stand heights.
I have a 34 intake that I want to use on 59ab and fuel pump stands off of various intakes. Doing a mix and match.
Brian 07-03-2022 02:53 PM
All the fuel pump stands, 34-48 are the same height. There are differences, but they all mount the pump the same height from their base...Your 34 intake requires the use of the long push rod [8 7/8"]. Any fuel pump 34-48 will mount to any 34-48 fuel pump mount.
36coupe 07-04-2022 10:38 AM
Okay Thanks
Ziggster 07-05-2022 07:28 AM
1 Attachment(s)
I’m doing the same. Got an earlier Ford aluminum intake with the vacuum port for the helmet distributor since I decided to use it instead of the crab style one that came with my C59A. I actually purchased both style fuel pump rods as I was still not entirely sure what was needed with what and exactly which direction I was going at the time. Also, the original (long version) was worn as well.
