The Ford Barn
-   -   ‘34 coupe dash mounting question (https://www.fordbarn.com/forum/showthread.php?t=314411)
Digger 06-13-2022 01:56 PM
Putting the dash back in, can’t remember if there is SUPPOSED to be any kind of rubber strip or fender welting in between the dash and the body?
highbeams 06-13-2022 03:35 PM
Re: ‘34 coupe dash mounting question
Digger-
If you've seen my posts, I am/was in the process of removing my '33 3w dash for woodgrain'g. But now I understand that woodgrainers are extinct. AND no person nor entity does the '33/'34 burled-walnut. Presently, my windshield frame & new Sanders glass is stilll not on/in the windshield cab opening. I do not see a rubber strip or fender welting in between the dash and the body. Although I do not have the dash completely out at this point, so . . . if there is a rubber strip/fender welting, I am unaware of it. But if you're in San Luis within the next couple months, you are welcome to stop by and view the 3w at the area you are concerned about.
Digger 06-13-2022 03:59 PM
1 Attachment(s)
Thanks HB….note photo of my dash, woodgraining I just completed recently. with the glove box radio. I just put the face on from a working unit for the looks, will deal with installing the box at a later date
DavidG 06-13-2022 06:00 PM
highbeams,
Your post above suggests that you have forgotten or did not bother to read the responses on wood-graining sources on the thread that YOU started on October 2, 2021 wherein three sources were cited by knowledgeable 'barners'. Both '33 and '34 (they're slightly different) wood-graining is available.
johnboy34 06-13-2022 07:13 PM
I have no pictures but when I disassembled my tudor I recall there being welting there along the edge of dash to body. If there wasn't you'd see the top edge of the cowl flange.
highbeams 06-13-2022 08:27 PM
Originally Posted by DavidG (Post 2138498)
highbeams,
Thank you. David G. I will view the Ford Barn again. I didn't see the three specific names
you allude to. Thanks very much, again.
highbeams
David J 06-13-2022 10:17 PM
Yessir as usual:D
highbeams,
cas3 06-13-2022 11:51 PM
Not an expert, but I believe the dash for my 3W had the remains of some fabric along the top where it meets the body
Newc 06-14-2022 12:14 PM
Probably a 'squeek' preventer. Newc
Scott/Mn 06-14-2022 03:34 PM
2 Attachment(s)
There is welting material in front of the dashboard on my '34 Ford. I believe the car is original and has not been disassembled.
rich b 06-14-2022 07:51 PM
Not to speak of '34s; but I have taken apart two '33s that had a strip of fabric/tape like anti-squeak stuff between the dash and cowl. No bead like fender welt. Both were field cars that would have been unlikely to have been disassembled unless early in their lives.
Digger 06-14-2022 08:52 PM
Ok thanks everyone, so still have the choice of fender welting, rubber/cloth tape stuff, or nothing…it’s not a car to be ever judged, so I guess will go with personal preference as I gotta move on and just put it in. Don’t have any of that stuff on hand, so will see how it looks without
STAN WHITE 06-14-2022 09:44 PM
I have a 34 3wdw that is original. It has welting between dash and body. The welting is much smaller than the fender welting. It looks just like the pictures showen above. Stan
ssffnomad 06-14-2022 09:55 PM
2 layers of black friction tape to keep the squeaky down.
Worry less , Drive more.
Stretch
Digger 06-14-2022 10:25 PM
Nice… black friction tape, grand idea
cas3 06-14-2022 11:33 PM
Hockey stick tape is what to ask for as the folks at the store have never heard of friction tape. We are obsolete ya know
