driveshaft yoke Hello, I am working on my 56 Mercury Montclair. I replaced the transmission tail seal due to leaking. After driving some miles it is leaking again. I notice that it is not leaking from between the housing and seal, it is leaking from between the yoke and the rubber of the seal. I removed the driveshaft again and inspected the yoke, it does have a wear ring where the seal rides. A couple guys had told me to replace the yoke. The problem I am having is finding a yoke specifically listed for a 56 Mercury.
Has anyone had to replace their yoke on this model car? If so, do you have a company name/part number? If anyone has any suggestions, I would surely like to hear. Thank you. |
Re: driveshaft yoke Two suggestions. The seal does not have to be in the same place the old one was. You can either leave 1/8 inch or so outside the transmission case or possibly drive it about 1/8 inch farther in. The other suggestion is to install a speedi sleeve over the yoke. You need a good set of calipers. https://www.skf.com/us/products/indu...-speedi-sleeve
Re: driveshaft yoke If there is a bushing inside the tail shaft casting, to locate the yoke, a speedi-sleeve may not pass thru the bushing
Re: driveshaft yoke |
Re: driveshaft yoke ck with Van Pelt sales, they may have one.
Re: driveshaft yoke Usually the seal leaks because the bushing is worn. Should replace both at the same time. The grooved yoke needs to be replaced also.
Re: driveshaft yoke I am sorry that I forgot to say, I have the Merc-O-Matic transmission. It is a 16 tooth spline. There is no speedi-sleeve on the yoke now, and I don't see any sign of one having been on there. I measured the outside diameter with my caliper to be 1.682. The 1 5/8 sleeve lists the diameter range 1.622 - 1.628. I will try to clean/polish it some more to see if the measurement changes.
Re: driveshaft yoke Quote:
I was gonna suggest Speedi-sleeve too. They are slick. I used to sell them many years ago. Saves a lot of headaches and a lot of $$$ |
Re: driveshaft yoke It shows how far I am from current tech -
Re: driveshaft yoke That 16 tooth spline fits late 40's trucks through the 50's pickups, if you can find one with all the same measurments at yours, new ones can be had.
Re: driveshaft yoke :confused: ... excuse me ... I am a little cornfused here ... I gave both the FORD PN (to SEARCH for NOS) and the DANA-SPICER PN (current) and all are still asking where and why. Is it my browser carousing, is it my breath or am I on the :eek: IGNORE LIST :eek:? Quote:
Re: driveshaft yoke Thank you. I will be checking on the part numbers with the companies. I can't seem to find a speedi sleeve for 1 11/16 inch shaft and I don't know if turning it down to 1 5/8 would be a good idea. I will update with what I find out.
Re: driveshaft yoke No, don't even think about turning it, that would totally defeat the purpose. I have a '97 Dodge/Cummins work truck. It has speedi-sleeves in the front spindles, the rear axles and the engine cranshaft snout. All because the seals have worn a groove into the rotating mass. Speedi-sleeves have a range of what they fit. 1.682 needs to fall within that range. Their website is a mess right now. For some reason I can't get the correct part number based on inches.
Re: driveshaft yoke well I ordered a speedi sleeve today! Hopefully it will be here in about 5 days. I will report on how it goes for installing and if it cures the ATF leak. Thanks for all the info, I sure appreciate it. It sure makes working on this car a lot more fun when you have others for help and tips and to share in the excitement of fixing things!
Re: driveshaft yoke While you are waiting for it you'll need to source an installation tool. It can be PVC or a metal pipe/tube that will slip over the yoke shaft, the closer the better. You will also need a lubricant to coat the shaft, I use bearing grease.
Re: driveshaft yoke Update: I finally got my speedi sleeve installed. I had a delay because after I received the sleeve that I ordered, I realized that it was not wide enough to have both lips of the seal ride on the sleeve, so I ordered a second one. I measured and installed them so that they are just a hair apart and now each lip of the seal is riding on a sleeve.
Due to rainy weather, I was not able to drive the car today. I am looking forward to seeing if this solves the ATF leak! |
