The Ford Barn
-   -   Spin on oil filter (https://www.fordbarn.com/forum/showthread.php?t=312740)
C1Nelson 04-28-2022 07:19 PM
Spin on oil filter
I have one of the Spin On Oil Filter kits on a motor I will be putting in my CCPU project. I also found an adaptor to change the filter from a horizontal position to a vertical position. The adaptor is a Ford oil filter mount #97JM6884AA. I know others have used this adaptor.
The adaptor screws on to the motor using a bolt that is the same size as the nipple on the valve cover.
Can someone tell me if the nipple on the valve cover can be removed?
John 04-28-2022 07:49 PM
Re: Spin on oil filter
Yes, the pipe nipple unscrews on the ones I have seen.
john Cannon
