Tudor driver door sliding lock install and correct function? Hi I have never had the drivers door sliding lock installed and now that I have installed it I must have done something wrong or something is missing or broken. When the slide is in the locked position I can still turn the outside handel and open the door. What is the slide supposed to contact in the latch assy to make this work and how is it supposed to work when working? It seems like this should be a very simple install so what am I missing?
Re: Tudor driver door sliding lock install and correct function? 1 Attachment(s)
Sliding lock should push against the door latch as shown by the red arrow.
Re: Tudor driver door sliding lock install and correct function? Something may have gotten bent. Sliding to the left locks, and to the right unlocks.
Re: Tudor driver door sliding lock install and correct function? sometimes the finish bezel that surrounds the lock knob gets installed to far forward or back not letting the slide go far enough to engage the lock. moving the bezel a wee bit sometimes helps.
Re: Tudor driver door sliding lock install and correct function? When I purchased mine the lock on the drivers did not function. Purchased a new assembly, and when tightened, the door handle was very tight to operate - almost unusable. I lined up the two assemblies and found the screw hole to mount to the door was a little bit off the original I was replacing. After I rounded the hole a bit to accomodate the offset, reassembled and worked perfectly.
